04-02-2015, 07:31 PM
(04-02-2015, 06:46 PM)KOVKID Wrote: Nice looking job PJK
How do the regs work with adding 18mm to each side of the cab above hob?
I have done a few door refurbs and yes they are worth doing.
I had a replacment door enquiry today where they want a gloss white door on to a oak cab' should be interesting
Strictly speaking it wouldn't meet regs. but it didn't before as it doesn't look like PJK replaced the worktops or the hob so the original gas installer shouldn't have done it.
The standard regs are normally a set height off the burners and normally 50mm to the sides.
To be honest I would have probably done the same as PJK, advise them it doesn't meet regs but as you're not touching that part, you let them make the choice.
Before anybody shoots me down in flames (pun intended) I know that as soon as you flag up an issue you are strictly liable for it, but if it was something I thought was dangerous I would refuse to do it, clearly in this instance its lasted for many years without issue, so whilst I wouldn't design a kitchen from the off like it, I also wouldn't be a jobsworth and insist it was changed.
