04-02-2015, 06:01 AM
Finished a door replacement yesterday. I do quite a few of these. They're fiddley but at times the final result is quite a change.
The befores.
adkilled/media/DBCCEBA3-A2D7-45EA-BD36-E447DD9B7513.jpg.html][/URL]
There was quite a bit of work in this one. New extractor and ducting, Le Mans, new soft close drawers, int fridge and swapping the hinging of the 300 wall units. As normal with this type of job the units were all pissed and lining things up took quite a bit of doing. For instance the esp on the RHS of the draw run is rebated 5mm from top to bottom to keep the lines running right. Before I started I made the customer aware of the 5 ring gas hob problem!!
The customer is doing his own lights.
Sorry stretch just looked and the images aren't the right size. I'll try and edit that later.
The befores.
