28-02-2010, 04:45 PM
nskitchenfitting Wrote:marc1106 Wrote:nskitchenfitting Wrote:theNovice Wrote:marc1106 Wrote:does that plate have a series of very small holes running in a line through it if so that bracket actually goes in the top of the D/W to secure it to adjacent units, usuallt the brackets for the doors are surface mounted then after slotting the door in place you remove 4 screws from the inside of the appliance door and replace them with longer ones that go through the appliance door into the decor door from inside!
My drawing includes lines of '.'s because the drawing goes out of whack when I preview my posting - so no series of small holes. The only holes in the plate are for four fixing screws - 'O's in the case of my drawing.
However, I didn't know about going through the d/w door from the inside to grab the decor door... will have another look at the plans!
Thanks again!
you dont need to recess them, if you look at the dishwasher you should notice that the top of the door (The plastic moulded area) is proud of the lower area.
ERM,, what if its fully integrated NSK?
that is what i am talking about?
assuming its baumatic (same as f/f) the door is assembled as i described above... the top run of the appliance is proud by about 3/4mm which allows for the brackets on the lower half..
yep, after my post i realised id missunderstood what you were saying
I didn't fail the test, I just found 100 ways to do it wrong.
Benjamin Franklin
Benjamin Franklin
