27-02-2010, 10:02 PM
theNovice Wrote:nskitchenfitting Wrote:you shouldnt need to recess the brackets. they normally sit internally on the d/w.
I could have it completely wrong, but the brackets I'm referring to are two square metal plates (for the bottom of the furniture door) that have a 'hook' - like if you cut a tab from the middle of the plate then bent it: (i can't represent the bend in my artwork!)
____________
|..O.. ___..O..|
|..O..........O..|
From the technical drawing it looks as though you're supposed to fit the bracket flush on the furniture door (meaning the thickness of the bracket is recessed or routed out).
The bracket secured to the furniture door then slots into the d/w door front.
does that plate have a series of very small holes running in a line through it if so that bracket actually goes in the top of the D/W to secure it to adjacent units, usuallt the brackets for the doors are surface mounted then after slotting the door in place you remove 4 screws from the inside of the appliance door and replace them with longer ones that go through the appliance door into the decor door from inside!
I didn't fail the test, I just found 100 ways to do it wrong.
Benjamin Franklin
Benjamin Franklin
