21-01-2015, 02:02 PM
Hi Kitchen Experts,
DIY enthusiastic and kitchen amateur here who is about to try and fit a cheap DIY kitchen (or at least get as far as possible before screaming for help...)
I plan to feature base units along the wall and coming out into the room to form an 'L shape' breakfast bar (please see the kitchen plan attached).
My question is, what is the correct type of base unit to form the breakfast bar?
I have assumed the correct unit is the 'L-Corner Base Unit' however I have seen you can also get this type of corner base unit - Which is the most appropriate unit to buy for this purpose?
My second question as these units won't be fixed to the wall, what is the best method to fix them to the floor?
If you can provide any advice or direction it would be every much appreciated.
Many thanks for your help.
Stuart
Stuart
