07-10-2017, 02:29 PM
Lights in the section LH of the ovens miss-aligned?
Daniel's Latest .....
I've just realised I might get slated for this because all the stuff you lot have pointed out is probably worse
07-10-2017, 02:31 PM
07-10-2017, 02:34 PM
True Handless handle perhaps should have run above the open shelf unit in the Island...?
07-10-2017, 03:01 PM
nop ..... it has something to do with the appliances.
07-10-2017, 03:26 PM
The height of the Oven is not the same height as the Compact + warming drawer...? you have had to put a filler in ?
07-10-2017, 04:44 PM
it only works out as a couple of mm different at the bottom when you have that oven set up. Done it plenty of times, so wouldn't call it a mistake unless the customer was expecting it to line through perfectly?
07-10-2017, 06:24 PM
Ok perhaps it's too brand specific then ....... the warming drawer is wrong.
Miele do two types, with this side by side set up the warming drawer top steel section should line up with the oven next to it. The warming drawer I accidentally ordered is the one with the slimline steel section so the steel doesn't flow through. Annoys the hell out of me, but perhaps life's too short Can someone resize those images, they are massive on my iPad as well.
07-10-2017, 06:41 PM
(07-10-2017, 06:24 PM)Daniel Wrote: Ok perhaps it's too brand specific then ....... the warming drawer is wrong. Lol... Should look like this then but still looks odd to me as the compact shouldn't have the S/S strip with this setup ...: This to me looks better!: |
Possibly Related Threads… | |||||
Thread | Author | Replies | Views | Last Post | |
Daniel's Latest Design .... | Daniel | 21 | 23,087 |
22-05-2019, 01:36 PM Last Post: Daniel |
Daniel's Latest | Daniel | 22 | 31,786 |
22-06-2017, 11:02 AM Last Post: Daniel |
Daniel's Latest | Daniel | 39 | 66,489 |
14-01-2017, 01:33 PM Last Post: David Owen |
Daniel's Latest | Daniel | 25 | 43,999 |
30-01-2016, 05:18 PM Last Post: stejoke |
Daniel's Latest - Sort Of !! | Daniel | 19 | 40,671 |
16-01-2015, 11:57 PM Last Post: Daniel |
Daniel's Latest | Daniel | 17 | 35,317 |
05-11-2014, 11:16 PM Last Post: Daniel |
Daniel's Latest | Daniel | 12 | 28,801 |
21-08-2012, 09:47 AM Last Post: Daniel |
