23-03-2016, 06:40 PM
Hi
I'm new to the forum. I've fitted a few kitchens over the years (competent DIYer , not a pro) , I take my time and try to think everything out before jumping in. I've never fitted wooden worktops and upstand before , i have researched quite a bit, so I understand about allowing for expansion gaps , and elongated carcase fixings and oiling/sealing ....but I still have some questions I cant find the answer to:
1/ The foil stuff for fitting to the underneath of a worksurface where an appliance is fitted. I cant find it online. Does it come with an integrated appliance ?
2/ With the order ( I didnt ask for it) , I have matching Oak upstands. 18mm thick and 40mm high, I'm in two minds whether I should use them or just tile down to the worksurface ( the tiles will be 8mm thick so will allow for expansion of the worktop). Heres the main decider for me , I will be having a gas hob ( and a gas safe engineer to do the honours), so can I use the upstand behind the hob ? Whats the regs. on that? Stopping and starting it I think would look a bit crappy ( as well as give me more tile cuts to accommodate doing so).
3/ Joining, I've heard different opinions . Do I / should I join with a scribe & butt joint ( also referred as a hockey stick join or male/female join) or do I just route for the fixing bolts and have a straight edge butt join? Also whats the best thing to seal the joint with??
4/ One stretch of work surface is going to be 3150mm long, I cant get a long than 3m length , so will have a join and use one of the off cuts ( 600mm long) , but should I just use 150mm and biscuit joint it or bigger to accommodate fixing bolts?? I am not sure what would look or work best?
Really appreciate any advice on this ,
Thanks
Thanks
