05-06-2009, 05:07 PM
very impressive Ijust borrow the jig from the workshop which is from pws
worktop radius
05-06-2009, 07:10 PM
had a proper jig until some thieving bar steward decided to lighten the load on my van a few years ago now I have one made from mdf almost identical at a fraction of the cost
22-02-2011, 12:16 PM
Excellent description for the outside radius, but has anyone done one for an inside radius. I have a Magnet kitchen to fit which has an inside radiused corner cabinet, worktop is american black walnut. Any help would be gratefully received.
22-02-2011, 12:40 PM
For an inside radius, I'd use the same jig to make a template in 9 or 12mm MDF, then clamp that to the worktop & cut with router & 30mm collar.
Insert amusing/intelligent/witty comment here
22-02-2011, 01:07 PM
jonny round boy Wrote:For an inside radius, I'd use the same jig to make a template in 9 or 12mm MDF, then clamp that to the worktop & cut with router & 30mm collar. My radius is at the corner of a 600mm long surface and 900mm bar at right angles. So do I biscuit join a piece onto the side then cut?? Other problem is that a sink has to go in this corner too, a small 450 dia stainless. Not ideal for jointing but will well glued biscuit joints work??
22-02-2011, 01:48 PM
Guest Wrote:jonny round boy Wrote:For an inside radius, I'd use the same jig to make a template in 9 or 12mm MDF, then clamp that to the worktop & cut with router & 30mm collar. I'm not quite sure what you mean - I was going to suggest you post a picture, but since you're a guest I don't think you can. Could you explain it a bit more?
22-02-2011, 02:01 PM
jonny round boy Wrote:Guest Wrote:jonny round boy Wrote:For an inside radius, I'd use the same jig to make a template in 9 or 12mm MDF, then clamp that to the worktop & cut with router & 30mm collar.
22-02-2011, 02:07 PM
Hi not sure if links work but you can see the inside corner to the back of this, where the kettle is.
http://www.magnet.co.uk/magnet-kitchen-c...-lineaire/ |
