09-10-2016, 04:34 AM
A Lag Screw is meant for improvising on or increasing the surface area that the nut and the bolt have been locked in to. A professional has the option to choose from a variety of shapes, diameter and thickness.
Also commonly referred to as flat disks, the flat washers are normally used as buffers between metal parts or also as spacers to offer friction reduction and cushioning and also to ensure that loads are evenly distributed. You will find the washers being used in reducing the vibration and movement that is normal between two moving parts that are heavy. They also are helpful in providing that smooth flat surface for a part to fit tightly to the other or move smoothly over the other part.
Flat insulation washers are important in many applications where compatible and strong connections are required for incompatible metals. Such pieces are placed in between incompatible pieces to allow a smooth functioning.
Such washers are also ideal for electrical insulation. There are flat shoulder washers which are usually used in mechanical applications where vibration can be reduced while providing a strong resistance to corrosion. These washers can be found in flanged or standard design. Standard washer spacers can be used on standard thread sizes.
Flat washers are usually made of nylon with natural color; they are designed to be tough although they look trivial and flimsy but they are designed to resist corrosion and various acidic chemicals.
Retaining flat washers are specially designed to grip the outside of a screw shank strongly but allow easy slides on the screw. They would retain their firm position once assembled on. Hence, the assembly time is reduced as they are easy to fit. They must be available for domestic consumers as well as international customers if they wish to be progressive. One can request for a free catalog to view the availability of Head Wood Screws desired and make an order easily through a phone call, walk in or online.
