06-10-2010, 10:48 PM
Hello,
Does anyone know if it's possible to fit a 90cm gas hob that has an 850mm cutout over a pan drawer which is 80cm wide or (alternatively 2x 60cm wide pan drawers)?
The worktop would be laminate, around 40mm thick and the hob says it needs 80mm space below it - so would I need to chop the top bits off the pan drawer to make the space? Does anyone have any experience of this type of situation? I'm kind of in a bind over this as I'd like to use IKEA cabinetry but I've just found out there may be a problem.
Any help would be highly appreciated!
Thanks
Thanks
