Laser level for kit hint fitting - Printable Version
+--- Thread: Laser level for kit hint fitting (/showthread.php?tid=6621)
Laser level for kit hint fitting - Harry1977 - 15-10-2016
Hi fitters
Does anyone use a laser level to set out there kitchens??? Been looking at this and wondered if it was worth the money
Cheers
RE: Laser level for kit hint fitting - Daz Gizmo - 15-10-2016
When they first came out I worked at Davenport Cabinetworks in Nottingham and I became a bit of a geek with Laser Leveling when I was fitting.
They are great for finding the highest spot in a room and checking verticals for twist.
I also used to use the beam as a straight edge for long runs of base and wall units...
This youtube video shows one in use:
RE: Laser level for kit hint fitting - Stretch - 15-10-2016
Get a Laser level. You won't regret it.
So useful for everything....setting out base cabs, socket datum, tling. Guaranteed your regular spirit levels will stay in the van. Forever.
RE: Laser level for kit hint fitting - Claydon Lad - 15-10-2016
We still use the sprit levels though......usually to draw a straight line on an end panel ready to cut.... oh and to hang a jumper on occasionally !
Saying that, the laser levels are bang on. So useful. Get one. You won't regret it.
RE: Laser level for kit hint fitting - Harry1977 - 16-10-2016
(15-10-2016, 08:58 PM)Claydon Lad Wrote: We still use the sprit levels though......usually to draw a straight line on an end panel ready to cut.... oh and to hang a jumper on occasionally !
Thanks, which one do you use??
(15-10-2016, 08:46 PM)Stretch Wrote: Get a Laser level. You won't regret it.
Cheers
Which laser level do you use
RE: Laser level for kit hint fitting - Claydon Lad - 16-10-2016
This one.....
http://www.its.co.uk/pd/LINO-L2-Leica-LINO-L2-Self-levelling-Cross-Line-Laser-_LEILINOL2.htm?gclid=CLnT-NaC4M8CFUPgGwod-ucI3w
RE: Laser level for kit hint fitting - mezzyg - 16-10-2016
ive got this one, works extremly well has a tripod mount on the bottom and magnets on the side so fixes onto metal corner beading
http://www.its.co.uk/pd/DW088K-Dewalt-Professional-Self-Levelling-Cross-line-Laser-_DEWDW088K.htm
RE: Laser level for kit hint fitting - PREM - 17-10-2016
I use this one
http://www.tradetiler.com/stabila-lax-50-self-levelling-laser.html
