In-column fridge under counter ventilation - Printable Version +- Kitchen Fitters Forum (https://www.kitchenfittersforum.com) +-- Forum: Admin Section (https://www.kitchenfittersforum.com/forumdisplay.php?fid=8) +--- Forum: Archived (https://www.kitchenfittersforum.com/forumdisplay.php?fid=30) +---- Forum: Free Post (https://www.kitchenfittersforum.com/forumdisplay.php?fid=22) +---- Thread: In-column fridge under counter ventilation (/showthread.php?tid=2635) |
In-column fridge under counter ventilation - Guest - 27-03-2011 Hello everyone I have a fitted kitchen with an extra-high worktop (885mm clearance). I want to fit an integrated fridge but I don't like the inaccessible drop-in salad-boxes that they have due to the front ventilation. I would like to fit an 875mm height in-column fridge standing on the floor. Normally these have 200cm2 air vents at the base and top of the cabinet. I can fit a vent grille at the back of the worktop, and one at the bottom of the panel at the side of the fridge. There will be about 45mm gap between the panel and the fridge. I could also raise the fridge by 10mm to give a little ventilation underneath. Do you think this will provide enough ventilation? Will there be any other problems? I'd be very grateful for any advice. RE: In-column fridge under counter ventilation - PJK - 27-03-2011 Sorry but there is no chance of this working, (and looking ok) you would have to have the plinth opening with the door. Spend a little EDTA and get the neff built under, they have a shelf onto of the salad crisper that sliders out. RE: In-column fridge under counter ventilation - PJK - 27-03-2011 Project-Jon Wrote:Sorry but there is no chance of this working, (and looking ok) you would have to have the plinth opening with the door. Spend a little EDTA and get the neff built under, they have a shelf onto of the salad crisper that sliders out. EDTA is ment to say extra iPad predictive speller RE: In-column fridge under counter ventilation - ginsters - 27-03-2011 thats around standard height for a top? and a 870 in there going to be pants and more than possibly void the waranty and your plinth line will be out the window,there a reason why these big apliance companys design and manufacture there machines for set places a bit negative but the truth,i wouldnt do it for anyone or my self RE: In-column fridge under counter ventilation - Guest - 30-03-2011 Thanks for your answers guys - I will take your advice. |
