Earthstone white worktops - Printable Version +- Kitchen Fitters Forum (https://www.kitchenfittersforum.com) +-- Forum: Admin Section (https://www.kitchenfittersforum.com/forumdisplay.php?fid=8) +--- Forum: Archived (https://www.kitchenfittersforum.com/forumdisplay.php?fid=30) +---- Forum: Free Post (https://www.kitchenfittersforum.com/forumdisplay.php?fid=22) +---- Thread: Earthstone white worktops (/showthread.php?tid=2321) |
Earthstone white worktops - Guest - 02-11-2010 [/size][/font]Hi is there any one who can tell me what is the best way to cut a radius to match curved base units in earthstone worktops will come with kit and curved edging. Im experenced in kitchen fitting but not earthstone/corran worktops so wondering how to approch this issue as with laminate work tops with rolled edging its near impossable to get a seamless joint as far as i know only solid worktops ( wood/granite ) will give you seamless curved edges??? RE: Earthstone white worktops - voltarol - 03-11-2010 Get a solid surface specialist to do it RE: Earthstone white worktops - PREM - 03-11-2010 with earthstone you have to buy the jig and the ready made curve. the jig is just a crude piece of mdf that you clamp on and rout away. easy really just time consuming, job i had 6mths ago had 6 of them with a b/bar double curve. just like a laminate you start at the front edge. |
