small job - Printable Version
+---- Thread: small job (/showthread.php?tid=1976)
small job - marc1106 - 05-05-2010
changed from a built under oven to a range cooker
[Image: Image0184.jpg]
all 3 600 units removed along with hob and worktop
[Image: Image0185.jpg]
re sized 2 of the 600 units to 400
[Image: Image0186.jpg]
units back in and range in place
[Image: Image0187.jpg]
internal drawers fitted and end caps on worktop, range adjusted to height
[Image: Image0189.jpg]
new 400 doors on, re used handles, fillers in job done.
[Image: Image0192.jpg]
RE: small job - mammy - 05-05-2010
does the range only need 15mm copper? and are the ovens electric then.
RE: small job - marc1106 - 05-05-2010
mammy Wrote:does the range only need 15mm copper? and are the ovens electric then.
did the 2meter length of 6mm not give that away? Th_ROFLMAO
sorry mams, but yes its a dualfuel range!
RE: small job - chip off the block - 05-05-2010
looking at the picture the cable is rather obvious
RE: small job - Dave - 06-05-2010
Nice pics.. Why the half tile from the W/top..?
RE: small job - Edecko - 06-05-2010
How do you cut the tops right across in situ. Assuming that's what you did.
RE: small job - jonny round boy - 06-05-2010
Edecko Wrote:How do you cut the tops right across in situ. Assuming that's what you did.
Quote:all 3 600 units removed along with hob and worktop
'Nuff said.
Th_ROFLMAO Th_ROFLMAO Th_ROFLMAO
RE: small job - marc1106 - 06-05-2010
Dave Wrote:Nice pics.. Why the half tile from the W/top..?
i dont know Dave it was like that when i got there Cheers think it was to do with not having a cut along the window reveal?!
clamp the plunge saw guide rail at 90degrees to postformed edge and saw away leaves bout 50mm to do with a floorboard saw (CAREFULLY) of course! Cheers
