Hi from York - Printable Version
+--- Thread: Hi from York (/showthread.php?tid=6381)
RE: Hi from York - Daz Gizmo - 04-07-2016
Joe
Watch this video....hope this helps...  ThumbUp
This bedroom render shows a feature wall using a reflection texture that has a glossy relief pattern in the wallpaper material:
[Image: rrJohal%20NG9%203AZ%20-%202016-07-0421.3...yt2lnc.png]
RE: Hi from York - Joe Laughlin - 05-07-2016
(04-07-2016, 07:44 PM)Daz Gizmo Wrote: Joe
Daz, the little box refuses to be ticked so i can't select a texture. Had this working before but went back to normal settings in config file. Maybe i have done something in the config file? will load a fresh articad in vmware and test the config file.
RE: Hi from York - Daz Gizmo - 05-07-2016
Okay Joe
It sounds like something is amiss. I always save a copy of the original so if something goes wrong its easy to replace..
(05-07-2016, 11:48 AM)Daz Gizmo Wrote: Okay Joe
Daz,
Yes got it working now, it was the config file.
ThumbUp
RE: Hi from York - Chris - 05-07-2016
I'll try it again, but i definitely think i probably ticked the box.
Windows 10 or 7?
I just remembered that i downloaded your stainless steel texture (many thanks btw it is stunning, i use it often) i'll find the redsdk line in your mat file and that could be a way round it if i can't get the windows open file dialog to pop up.
Daz,
What was it you changed bud?
I am using Windows 7... I do not think the OS will affect this tweak. Check the config is correct.
Glad the S/Steel material is to your liking Chris... ThumbUp
If I have not mentioned before that once this option using RGB values and textures that most materials the RGB value should be greyscale only (Black (RGB 0, 0, 0) = no reflection, White (255,255,255) =max reflection).
Metals should have very little, if any, Diffuse value and as the colour is all in the reflection like light yellow for Gold etc...
RE: Hi from York - Chris - 06-07-2016
Just gave it another go and this is what's happening.
